calling all suspension/brake guru's...
searched... but found conflicting info. I am puttin 95 GSR rear disc on my 96 DX hatch. what control/compensating/toe arms do i use? I have searched but i find different answers. do i use all(3) of the integra arms? do i use some civic and some teg? I have compared the arms and they all look the same length but the integra lower control arm looks beefier, the other two look identical. Also, i want to replace all the bushings but only find a kit for the integra? I have found the trailing arm bushing for civic but all of the other bushings(control arm's etc.) i only find in integra. Please help with what i am supposed to use! Thanks...
Re: calling all suspension/brake guru's... (madmanmaigret)
Use your stock toe and U/L control arm. As for bushing use the kit for your the 96-00 civic. If you plan to change the trail arm bushing(which recomand you should) us OEM Honda.
Re: calling all suspension/brake guru's... (kaiba)
the trailing arm i have figured out. but for both control arms and toe arm where do i get bushings? just use OEM?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madmanmaigret »</TD></TR><TR><TD CLASS="quote">the trailing arm i have figured out. but for both control arms and toe arm where do i get bushings? just use OEM?</TD></TR></TABLE>
For the lca ES/Prothan makes for them. And for the toe and uca Prothane make them.
also i was wondering doesnt the civic LCA have no provisions for a sway bar? and if the LCA's are the same (i say the same because a replacement from megan or skunk2 is the same for both cars) wouldn't i be better to use the one from the integra to add a sway bar later?
RacerBoy
12
04-03-2003 08:06 AM
