92 Si- Wont Start-need help
Ok here goes..
Car:92 si
Motor: jdm gsr B18c
Well i had blown the motor around 8 months ago, had a rebuild done.. but i used the same head and it was no good.. so i bought another bare Gsr head, and a few days b4 i decide to do the head swap the car died on me when i was getting on the high way out of no where.. i wasn't pushing the car hard either, grandpa driving...
I couldn't get it started so i had it towed to the house.. and still couldn't get it started so i figured now was a good time to do the head swap.. so i got the machine shop to transfer all my internals over and then today i just finished putting the motor back together. and i got a new fuel pump\filter..
-The car has spark, took out my distrib. and it worked on a friends car, spark plugs are brand new-i bought them from a tune shop and he had gap'd the plugs b4 putting them in..
- the car has fuel, i hear the fuel pump turn on, checked the plugs to see if the injectors have power, the spark plugs get flooded w\ fuel after cranking the motor for too long.
i checked all the fuses and everything is good... air\fuel\spark... i even tried my ecu on my friends car and it worked... what more is there to check?
Car:92 si
Motor: jdm gsr B18c
Re: 92 Si- Wont Start-need help (spooncivic28)
well it could be anything...maybe a ground wire came loose/check ur ignition wire..the electrical part...could be bad....not the key hole the electrical part that plugs into ur key hole piece that goes to ur fuse box.....ur under hood 50 amp fuse...or may your timing belt is loose and jump time...try those ande see....
Re: 92 Si- Wont Start-need help (sirsi)
The car keeps cranking over and over.. it just won't start.. i checked all the fuses. all the grounds are connected good.. No CEL's...
and the timing is good we checked that too
if all your fuses (underdash and engine), fuel pump primes, lights on cluster come on, you have spark, and the car just keep turning and turning.
its your main relay. so common a problem that there is a post like this every week use your friends to test yours
if you look behind your hood release and about 6 o'clock you will see a silver box bolted to the bottom driverside kick panel area.
clip off clip your friends on.. and see what happens
Re: 92 Si- Wont Start-need help (spoonracer84eg)
I have an issue kinda like this and I found out that even though the 15amp fuse to the ecu wasnt fried, I replaced it with a 30 amp fuse and it fired right up. I didnt have any fuses with me so I used my defroster fuse just to get me home and she fired right up.
Re: 92 Si- Wont Start-need help (1dumbassscreenname)
I just finished using my friends Main relay and still no start.. just keeps cranking over and over.. and we checked the timing also
.....sigh........
Just finished doing a compression Test. here are the numbers
Cyl 1: 25
Cyl 2: 150
Cyl 3: 150
Cyl 4: almost nothing
Cyl 1: 25
Cyl 2: 150
Cyl 3: 150
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncivic28 »</TD></TR><TR><TD CLASS="quote">.....sigh........
Cyl 1: 25
Cyl 2: 150
Cyl 3: 150
Cyl 4: almost nothing</TD></TR></TABLE>
crap
Cyl 1: 25
Cyl 2: 150
Cyl 3: 150
crap
check rotor button and coil wire. my hatch died and wouldn't crank whatsoever, that was my problem. replaced them both at the same time, it coulda been one or the other, but i did both.
Cyl 1: 25
Cyl 2: 150
Cyl 3: 150
machine shop ??????
Cyl 1: 25
Cyl 2: 150
Cyl 3: 150
machine shop ??????
Re: 92 Si- Wont Start-need help (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std »</TD></TR><TR><TD CLASS="quote">
machine shop ?????? </TD></TR></TABLE>
You got that right, from the 1st rebuild. not the one i just finished getting the head done... go's to show- get it done right the 1st time, dont go the "cheap" route
gursh d
16
04-14-2008 09:50 AM
Elrusodan
11-19-2007 09:05 PM
