ClAMP OR WELD TEST PIPE?
Re: ClAMP OR WELD TEST PIPE? (Padawan)
my test pipe is 3 peices. (omni-power if that helps). should i weld them together or will it be ok?
Re: ClAMP OR WELD TEST PIPE? (EGhatch33)
i wouldnt weld it, just because you never know when you will need to remove it... i just went to car quest and picked up some exhaust gaskets and i bolted the test pipe in. Doesnt leak for me... so it should work for you too.
Multi-paradigm
Re: (ZipTieGUy)
^ Correct. Don't weld or clamp it, it'll be fine as long as you don't overextend it. If you have the proper catback, this shouldn't be necessary.
Tong.Y
01-02-2011 08:14 AM
