del sol cluster in a eg??
My temp gage stopped working the other day, i borrowed a buddys cluster to make sure and its the cluster. I can get a delsol cluster for pretty much free, but its a litlebit of a drive. i was wondering since the delsol is a eg chassis if the harness would work for it. thanks
Re: del sol cluster in a eg?? (JDM_Ej)
thanks, ive seen some similar things done but never a delsol cluster in a eg. i put a da cluster in, everything plugged in but the only thing that worked was the gas.
Re: del sol cluster in a eg?? (mkinpwrat12g's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mkinpwrat12g’s »</TD></TR><TR><TD CLASS="quote">thanks, ive seen some similar things done but never a delsol cluster in a eg. i put a da cluster in, everything plugged in but the only thing that worked was the gas.</TD></TR></TABLE>
well, if you rewire, you could make it work. I saw a civic that had a del sol dash conversion. Kinda cool, but it would be a bit of a headache if all you want is a good cluster... plus the del sol cluster is shaped different. The civic cluster is flat on the bottom... the del sol goes down on either end and is shorter in the middle... not sure if it would fit at all....
93CivicSI
22
01-22-2005 12:34 AM
