Stock exhaust question...
Will the stock exhaust from a 2000 si with a b series fit a 95 ex (d series)? i know the diameter is different, but i plan on using adapters. I just need to know if the bends are the same.
thank you!!
ps .. i searched but didnt find anything
thank you!!
Re: Stock exhaust question... (WreckedTeggie)
Check aftermarket cat back systems. If the part numbers between the model years aren't the same, then it probably won't fit.
Re: Stock exhaust question... (cambopheonix56)
You might have to modify the connection from the cat to the B pipe, and possiblly the length of the B pipe.
coletrain_eg
06-17-2011 08:18 AM
