any tips for passing smog with a high-mileage d15b7, california san diego.
well my sticker is due this month so i need to know what it's going to take to pass smog. i ordered a magna flow cat, which will be put on as soon as i up grade to 2.25 piping. the motor is a d15b7 with aprox 190k miles. what else can i do to help it pass smog?
I don't live in **** county there (CA) for them to inspect your car w/ a microscope but here's what I would do: I'd order a STOCK OEM cat from honda, use high economy/low emissions parts to make it pass...then you can swap 'em back out..
But maybe I'm thinking too farfetched here?
Re: (Syndacate)
just do a tune up. plugs, wires, cap, rotor, fuel filter, air filter, oil change, and get a new cat. make sure the timing is correct or else you will get failed. set it back more retard, it makes less NOx. i think on the d15b7 the timing is 14+/-2. put it at 12 BTDC
1 Post
the timing has to be within the spec for the car. if it is off, it will FAIL that portion of the test. so careful if you are going to retard the timing. in addition, i think you should be able to run your car at normal specs as long as it is in good running condition. go get pretested and find out if you even have anything to worry about. just because it has high milage doesnt mean you are going to fail. my 87 subaru had 240k on it and passed with flying colors.
roldan1986
10
03-15-2016 12:52 PM
spermdoggy
05-25-2012 06:20 AM
serious
08-05-2004 09:25 AM
