fule pump wont turn on
my car wont start because the fule pump is not turning on. besides the connections on the pump where are the other connections? also what else should i look for?when you turn the ignition there is no buzz from the pump turning on.
Pooping on children
Re: fule pump wont turn on (NScivic)
i can almost garauntee its your main relay, it is a common problem. the relay can be repaired all you have to do is take off the cover on the relay and resolder the pins on the p/c board the broken solder connection will have a ring aroud it inside the solder joint.
Re: fule pump wont turn on (jdm b18c ek4)
yes all cluster lights turn on. i can turn the car ignition on and off like 20 times and it will prime like once, but its a bitch today to move my car for street sweeping it took me like 5 miniuts
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
have you checked all of the fuses. I seen people that tried to do fuel pump kills blow fuses. Also does the car have a kill switch that you might not of know about because this happens alot.
try checking ur grounds...thats one thing that will make ur fuel pump not prime...i swaped my motor one time and i only grounded one spot and couldnt figure out why fuel pump wasnt priming...then i grounded 2 other spots it started working again
cute little bastard
Re: (NScivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic »</TD></TR><TR><TD CLASS="quote">where is the main relay located?</TD></TR></TABLE>
I'm guessing you have a 92-95 Civic?
its to the left of the interior fuse box (by driver's side lower dash)
There will be a 10mm thats holding it onto the dash. Should be a grey looking box
acidburn2k2
08-16-2010 09:08 AM
HawaiiCrx
01-06-2003 03:04 PM
