Transmission / clutch help. please!!!
I just replaced my manual transmission in a 95 civic 1.5L LX. I also replaced the pilot bearing, release bearing, clutch disk and pressure plate. Everything was going smoothly. I reversed out of my carport and driveway, about 40 feet, and it sounded good. I put the car into 1st gear, and about 5 feet later, I heard and felt a "pop" sound. Now the car wont move. The shifter feels like it is going into gear, but it will not engage. There is a faint grinding noise when it is any gear and in neutral, but the noise disappears when I depress the clutch pedal. The car can be pushed while in gear. Any suggestions would be greatly appreciated. Thanks, Bryan
Re: Transmission / clutch help. please!!! (sencarus)
did you put grease on the shaft where the throwout bearing goes?
Did you torque everything down to factory spec?
Re: Transmission / clutch help. please!!! (j-corleon)
Sure enough, I got under the car, and the drivers side axel had popped out. I havent had a chance to fix it yet, but would that cause both wheels to stop spinning? As you can see, I am not very automotive literate. Thanks for your help,
Bryan
Bryan
building boost
05-18-2008 09:18 PM
