Manual StartUp
Manual StartUp
I have a 94 Honda Civic Cx Stock.
I was just wondering if anyone knew how or had any tutorials on how to bypass the ignition so you don't have to step on teh clutch to start the car, a few people that have standard vehicles are able to start their car without steppin on the clutch but they don't want to share their secret, any help would be appreciated.
Thank You.
P.S. I want to start on this engine so if i mess anything up it won't mater cause ima be doing a swap.
Thank You.
Re: Manual StartUp (Bondeedo)
look at the clutch pedal assembly
near the top there will be a switch and a sensor with a plug and 2 wires.
you can eithre unplug the sensor and stick a paper clip in there. or cut the wires and then wire them together.
Re: Manual StartUp (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">look at the clutch pedal assembly
you can eithre unplug the sensor and stick a paper clip in there. or cut the wires and then wire them together. </TD></TR></TABLE>
Haha I should do this to my buddies car, scare the hell out of him.
Re: (SVOboy)
If your car has cruise control bypassing the switch will also eliminate the auto shut off of the cruise control and could do bad things the the engine. However I don't think the dx had cruise control as an option.
94EG8
20
03-25-2020 04:08 PM
JokerX-1.6T
06-08-2007 05:08 PM
mmmtrbolude93
06-29-2006 11:36 AM
arsenaldragster
Audio / Security / Video
20
04-01-2003 01:03 PM
