Compression Numbers for Mini-Me swap and what is the ratio?
Y7 block, Y8 head, OEM Y8 HG
#1 = 175
#2 = 170
#3 = 180
#4 = 175
is that good enough for turbo?
Also what is the compression ratio going to be? from what ive been reading it says 10.23 is that correct?
#1 = 175
#2 = 170
#3 = 180
#4 = 175
Re: Compression Numbers for Mini-Me swap and what is the ratio? (pumpkyn)
Well it should be 215ish if the 10.2 compression is right, however, they are very close together which indicates you are alright.
Re: Compression Numbers for Mini-Me swap and what is the ratio? (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">Well it should be 215ish if the 10.2 compression is right, however, they are very close together which indicates you are alright.</TD></TR></TABLE>
any idea what the ratio could be then and would it be good to trubo it
guys im gonna bump this,
i want to do this ive had cheap performance increase with dropping a built vtec sohc head on my d16z2 (sohc non vtec) however im a little worried the compressions gonna be a bit high i have 12:1 ycp pistons has anyone tried this and does it make my compression ratio to high?
