what ET do i need on my civic hatch
Old 07-04-2006, 02:03 PM
frampo's Avatar
Default what ET do i need on my civic hatch
i have a civic esi, i think is the same as the si, its a eg hatch, will a 4x100 ET35 or a 4x100 ET38 fit properly on my car??
Old 07-04-2006, 02:28 PM
FalkenSiR's Avatar
Default Re: what ET do i need on my civic hatch (frampo)
I have some 15x7 35ET on my car (95 civic 4 door) lowered about 2". I did have to roll my rear fenders. Under hard braking + steering I do get some rubbing in the front but definately nothing to worry about. I would kill to have these wheels in ET 40 Depending on your ride height, you have to adjust camber also. I had to add camber in the rear.
How low are you?
Old 07-04-2006, 02:30 PM
BlueIntegraBoy's Avatar
+38 would better than the +35
Old 07-04-2006, 02:38 PM
frampo's Avatar
Default Re: what ET do i need on my civic hatch (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">+38 would better than the +35</TD></TR></TABLE>
but will 35 still work on my car?
Old 07-04-2006, 02:51 PM
FalkenSiR's Avatar
Yes it would, but:
what height?
what size wheels?
15" ET35 fit in my car but i had to add camber in the rear and roll my fenders. That's with a 15x7
Old 07-04-2006, 03:06 PM
frampo's Avatar
Default Re: what ET do i need on my civic hatch (fast95eg8)
they are 15" wheels, i think that they are 15x6.5 or 15x7, with a 50mm or 60mm drop
Old 07-04-2006, 03:12 PM
FalkenSiR's Avatar
You are going to have to roll your fenders in the rear at least and can't have any sort of camber kit. At that height you can't have any camber because the wheel sticks out too much. ET35 is low for civics. You are going to rub in the front for sure at that height, specially with lots of camber. Which you will HAVE to run.
Old 07-04-2006, 03:15 PM
littleredcivic's Avatar
it also depends on the tire size you want to use.
Old 07-04-2006, 03:19 PM
frampo's Avatar
Default Re: (littleredcivic)
it would be 195/50/15 on the tyre size
Old 07-04-2006, 03:58 PM
with the 35 offset with a 6.5" width, you should be ok...with a 7 inch wide wheel, you are pushing it on rubbing and too narrow of a tire. if you can, get a 205/50r15 tire with a 7" wide wheel with a 38mm positive offset.
the all out kid
Suspension & Brakes
01-31-2009 10:07 AM
ef9robert
05-07-2008 09:38 PM
carbonk20
29
11-22-2005 11:58 AM
Richard.
09-21-2003 09:04 AM
watacivic
05-01-2003 08:45 PM
Quick Reply: what ET do i need on my civic hatch
