weird eg voltage problem?
i have a stock 95 coupe with the exception of a SAFC II (i had it in my old car so i just put it in since i had it). i have only had the car for a few weeks and 3 times in the past week something kinda weird is happening. 3 times i have noticed that the voltage has dropped while driving from the normal 14.4v to around the 12.4-13.0v range. my first instinct was the alternator was going bad. but if i shut the car off and start it immediately again it runs at 14.4v. it just has occured just driving around town and just kinda all the sudden drops voltage. if i rev the car really hard it will jump up about a half volt. i checked the belt to the alternator and it is good and like i said when i restart the car it runs at the correct voltage at idle and at speed. any ideas? im stumped
Re: weird eg voltage problem? (judunty84)
the electronic load detector makes it do that. mine does it, it agravates the **** out of me. if you chip you ecu you can turn it off.
Re: weird eg voltage problem? (JSPECSIR)
what is the purpose of the electronic load detector and why would it make the vehicle run at a lower voltage? so basically is this anything i should worry about?
i dont know why it does it, but if you leave you blower fan on 2 or higher it will stay up at 14v. that way it detects a load and keeps the voltage up.
sanimalp
28
07-28-2008 02:35 PM
