b16a2 dyno chart
Re: (mk2machine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mk2machine »</TD></TR><TR><TD CLASS="quote">yeah that air fuel is wierd. Get it back up at 14.7 and inject some alcohol.</TD></TR></TABLE>
huh? it looks ok on the high ends. 14.7? do you want him to blow it up?
Re: (turbociviccoupe)
you realize that 14.7 is sea-level a/f mixture. And by the way anybody who has ever seen an engine run rich knows that it isnt gonna blow up. theres only so much oxygen being sucked into the chamber and it will not burn fuel past 14.7 If you run it rich than you will just burn up your cat. If you run it wicked lean than you will burn the 02 sensor. My car runs 14.7 a/f with alcohol injection with an intercooler and aftercooler with a 32 psi boost and its fine.
Re: (mk2machine)
this guy is from the bay dude...14.7 afr means its running lean...what the hell are you talking about? and you dont need alcohol injection on a honda unless you are running very high boost. you just need to up the octane if your pinging.
