quick question
quick question
i have a d16z6 1.6 sohc vtec
so i was wondering lets say i titen the valve's a bit more than the regular
would i have more compresion would i begetting more power?
any help......
thanks
any help......
thanks
Re: quick question (doood)
but wodent it go a bit faster cuz they where to tight at first and some where lose so i went to get a valve adjustment and it went slower
Re: quick question (slayerfromhell212)
If they were adjusted properly it should run better. just cause your butt dyno says your slower doesnt mean your slower.
Its a Dseries for crying out loud. its not going to feel fast.
Re: quick question (LowSlow93Sol)
dude i have always felt the power on my car i use to chirp my wheels in 2nd gear now i really cant make them chirp in second i might just go and make them a bit tighter lets see what happens
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slayerfromhell212 »</TD></TR><TR><TD CLASS="quote">dude i have always felt the power on my car i use to chirp my wheels in 2nd gear now i really cant make them chirp in second i might just go and make them a bit tighter lets see what happens </TD></TR></TABLE>
Do it, I think we need thread showing the damages of over tightening your valves. Don't forgot to REALLY over tighten them, then hold the engine at 7000rpm afterwards...
Not.
Adjust your valves to speak and put the cover back on. Anything more will only DAMAGE things. Want to make your car faster? Get rid of your D series or boost it.
Not.
OK U OVER TIGHTEN UR VALVES AND CHANCES ARE THE DAMN THING WILL BARLEY START!!! JUST SET THEM AT STOCK... IF U WANT MORE POWER THAT BAD BUY A CAM
Chirping 2nd gear is not an indication of power. If you are going to adjust your valves, adjust them to spec. I don't have my Helms handy so I can't tell you want the gap tolerance is.
m-
m-
been there done that
you clutch is on it's way out from all that d series power. tool.
oh well lets c what happens anyways im going to buy a new motor maybe a h22 well thank ahahah pz
bump
bump
