s20 synchro hub ?
s20 synchro hub ?
ok so I am in the process of rebuild an s20 p20-b000 trans and I have a broken 3/4th synchro hub at least thats what I call it. it is on the mainshaft here is a picture
and i check majestic honda and from what i can tell i cant buy just that part it is part of the gear set, now the rebuild kit i am using just has the brass sychros itself plus bearing and seals but i need to get a new one of these pieces does anyone sell them or am i stuck buying the whole gear set below is the like to the parts site
http://www.hondaautomotivepart...SHAFT
Go Tigers!
you have to buy a 3-4 kit which is pretty expensive. Honda won't sell just the synchro hub by itself.
take it apart and inspect the synchro sleeve. try to get pics
if the sleeve is still good i MAY have a synchro hub that will work for you.
Re: (Bense)
everything else is ok i think i broke it during/after assembly cause i didnt notice it before, however i think the was already a stress crack because i wasnt like beating it with hammers or anything
D Tranny Guru
Re: (seabass10369)
I should have a few extras, check over the synchros though, the three locater tabs to be sure they are not damaged along with the blocker rings.
If you hurt the slider, I know I don't have many spares. I searched thru quite a few to send Dave @ SMS Products a good piece.
BBB tranny show it seems.......
Bone
Bauley
Bense
Bone
Bauley
Bense
Risky Business
Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">I should have a few extras, check over the synchros though, the three locater tabs to be sure they are not damaged along with the blocker rings.</TD></TR></TABLE>
You're still alive?
You're still alive?
Re: (instructor74)
yah and unless someone on here has a spare to sell i can pick up another trans for less than the 220 for the gear set
RC000E
Transmission & Drivetrain
04-06-2009 02:43 PM
