need help,car wont run
after swapping a 92 ls in a 96 civic ex the car wont run right , using the ex wire harness . can the distributor cause it , which distributor should i use
Re: need help,car wont run (1fast ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fast ek »</TD></TR><TR><TD CLASS="quote">after swapping a 92 ls in a 96 civic ex the car wont run right , using the ex wire harness . can the distributor cause it , which distributor should i use</TD></TR></TABLE>
Use an OBD-II dizzy or re-wire the plug on an OBD-I.
Re: need help,car wont run (Syndacate)
when you say re-wire the the plug to obd1, i dont follow you , the plug on the wire harness is obd2 been that the car is a 96 . if i use a obd 2 dizzy should it be from a ls,or it dont matter
nikech1
09-17-2006 08:33 PM
carbonblackeh
01-13-2004 06:00 PM
