clutch pedal free play adjustment ( anyone know how? )
after replacing my flywheel and clutch i noticed the let off points wayy lower ( idk if thats normal or not)
but i was told to adjust the free play of the pedal could any one here tell me how to do so?
thanks
thanks
D Tranny Guru
Re: clutch pedal free play adjustment (EKlum)
myself, I've never messed with it.
I've likely had more used clutch combos and I KNOW FOR FACT more trannys in my car than anyone else.
Dying/leaking clutch master cylinder, I just top off the fluid every 5k mile oil change.
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
look at the pedal assembly. it is very straight forward. if you cannot figure it out by looking at it, then you should not be changing making any adjustments...
actually that helped me out alot.. but im still not likeing the spongey feeling it gives it seems to be leaking a little bit of fluid from the m/c maybe its time for a new master cylinder
after 250xxxmiles its time im sure.
Lude@Heart
Transmission & Drivetrain
01-12-2012 12:45 PM
sp00led
10-13-2011 12:16 PM
