Q about air conditioning install
Old 01-30-2007, 03:13 PM
black7hatch's Avatar
Default Q about air conditioning install
is it hard to do? im sure i could find the right stuff at a junk yard but is it worth it? the problem is i have a 98dx and i might be moving to AZ this summer. here in oregon it doesnt get that hot but down there i will want to hav AC. is it hard to do?
Old 01-30-2007, 05:02 PM
Default Re: Q about air conditioning install (black7hatch)
need help please
Old 01-30-2007, 05:05 PM
HCJDM1's Avatar
has your car ever had an AC before ?
Old 01-30-2007, 05:08 PM
hatchi's Avatar
not hard at all just get all the parts needed. in my opinion the hardest part is puttin in the Freon.
Old 01-30-2007, 05:13 PM
philosofy1's Avatar
Default Re: Q about air conditioning install (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">not hard at all just get all the parts needed. in my opinion the hardest part is puttin in the Freon. </TD></TR></TABLE>
and even that is not hard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black7hatch &raquo;</TD></TR><TR><TD CLASS="quote">is it hard to do? im sure i could find the right stuff at a junk yard but is it worth it? the problem is i have a 98dx and i might be moving to AZ this summer. here in oregon it doesnt get that hot but down there i will want to hav AC. is it hard to do?</TD></TR></TABLE>
if you are moving to AZ, you will regret not putting i the a/c. there is nothing like have it when it's 100 degrees outside, especially when you have a pretty lady in the car and her make up is running because you don't have a/c.
Old 01-30-2007, 05:21 PM
HCJDM1's Avatar
Default Re: Q about air conditioning install (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
if you are moving to AZ, you will regret not putting i the a/c. there is nothing like have it when it's 100 degrees outside, especially when you have a pretty lady in the car and her make up is running because you don't have a/c.</TD></TR></TABLE>
lol ... aaaah great .
been there done that .. loo now weve been going out for 1 and a hlaf years .. and i still have no A/c
i just live in AZ ... but this summer pasadena was getting to about 105 it sucked ...
Old 01-30-2007, 05:23 PM
philosofy1's Avatar
Default Re: Q about air conditioning install (HCJDM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HCJDM1 &raquo;</TD></TR><TR><TD CLASS="quote">
Old 01-30-2007, 05:28 PM
well i have never had AC in the car does that make a difference? i was thinking about just going to Upull it and finding the right stuff. what do i need? and how much do you think it will cost about?
Old 01-30-2007, 05:35 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black7hatch &raquo;</TD></TR><TR><TD CLASS="quote">well i have never had AC in the car does that make a difference? i was thinking about just going to Upull it and finding the right stuff. what do i need? and how much do you think it will cost about? </TD></TR></TABLE>
well, i purchased mine for my 93 dx on ebay i paid $300. so if you go to a salvage yard and pull it yourself, it should be alot cheaper.
hmm...you will need:
1. condenser (make sure the fan comes with it)
2. compressor
3. evaporator
4. dryer
5. hard lines
6. a/c switch for the a/c controls.
7. freon
8. new compressor belt ( that's if your civic has the pulley for the a/c if not)
9. crank pulley
10. start the car, turn it on and go pick up the first hot chick you see and take her for a ride.
oh, and if my list is missing anything, feel free to add!
Old 01-30-2007, 10:17 PM
hey thanks alot. hopefully i can find it for cheaper.
Old 01-30-2007, 11:13 PM
fasthatchb18c1's Avatar
Just make sure the compressor, lines, receiver/dryer, and fittings are for R-134 or R-12. Don't mix and match.
R-134 would be best if buying new parts.
Old 01-31-2007, 10:09 AM
philosofy1's Avatar
Default Re: Q about air conditioning install (fasthatchb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fasthatchb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">Just make sure the compressor, lines, receiver/dryer, and fittings are for R-134 or R-12. Don't mix and match.
R-134 would be best if buying new parts.</TD></TR></TABLE>
he has a 98 civic dx, there is no r-12. only r-134.
Old 01-31-2007, 10:19 AM
whoops That didn't even register till you pointed it out. I'm too used to fooling with cars that need a retrofit.
Old 01-31-2007, 04:15 PM
whats the difference between r-12 and r-134?
Old 01-31-2007, 04:53 PM
R-134 has smaller molecules than R-12 and R-134 is better for the O-Zone.
Old 01-31-2007, 05:46 PM
MonkeyBoy668's Avatar
From what my contractor friends tell me, it can be kinda painful to get R-12. Evidently my state requires a ton of paperwork, and the federal paperwork isn't anything to sneeze at either.
This isn't an issue though because with 98 you're not going to be able to use R-12 parts - all the cars in your generation (1996-2000) had AC systems designed for R-134. If you find an R-12 system it won't work on your car without some extra effort (and probably $), because it's for a different generation Civic.
BTW, are you sure he needs an evaporator? I remember hearing they built that bit into all models, because it's a PITA part for a dealer to install. Though maybe that just applied to newer (200x-ish) models.
Old 02-09-2007, 03:17 PM
HCJDM1's Avatar
Default Re: Q about air conditioning install (MonkeyBoy668)
i got a new compressor ... if i were to take the old one out ... and put the new one in what oil would i have to use on the compressor. and beside draining the a/c system what else would i have to do ?
scrcrw
24
08-24-2007 08:09 PM
not2fast
09-04-2006 10:28 AM
92b16si
06-11-2006 12:41 PM
vietherbs
Honda S2000
05-28-2006 03:13 PM
SojournMystical
07-03-2005 12:12 PM
Quick Reply: Q about air conditioning install
