rear disk brake
Re: rear disk brake (spaceman00)
Searching would help you a ton.. There is quite a bit of information available on the topic.
Either way. If you are using the whole trailing arm setup off another car, you can use any 88-00 Rear trailing arm/disk setup. The changes you will have to make is having 99-00 si rear brake lines, e-brake cables, and prop valve.
If you want to do the extra labor, you can pull just the disk part off the trailing arms, but in my experience, it is much easier to drop the entire trailing arm assembly.
The difference if you plan to use certain trailing arms is that the trailing arm bushings on certain years have different diameter bushings. I am not able to tell you exactly which years use which sizes, but that information is on here somewhere. All this really means is that you need to keep up with what vehicle you got your parts from so that in the event that you rip or just want to replace the bushings, you can order the right size replacements. Search disk swap, brake swap, or something along those lines.
Re: rear disk brake (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote"><===
90-01 Integra
92-95 Civic EX ABS
92-95 Civic Si
94-97 Del Sol VTEC
93-97 Del Sol Si
99-00 Civic Si</TD></TR></TABLE>
I didn't think to break it down like that
90-01 Integra
92-95 Civic EX ABS
92-95 Civic Si
94-97 Del Sol VTEC
93-97 Del Sol Si
mingbling96
05-06-2006 09:55 PM
ncVTEC1313
06-03-2004 05:14 PM
