LS in ek what throttle cable
Re: LS in ek what throttle cable (7808)
ummm you can't use the single cam throttle cable...too short...gsr is made differently so you are stuck with an ls throttle cable...you can use one from a da..it'll still work...gl with the swap
Re: (pdiggitydogg)
Im using the OEM GSR cable in my EK with the GSR swap.. but the intake manny is diff than a LS.. so it might be a shorter or longer cable than what your looking for.. but i know that its a tight fit.... good luck
Re: (JDMKid71)
I used an EX throttle cable in my ek hatch. I did the ex manifold swap when I still had my stock d16y7 in. I did an ls swap in mine, and used the same throttle cable. Perfect length.
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">I used my LS cable on my LS motor .... wild concepts.</TD></TR></TABLE>well the swap didnt have a cable neither did the car.. not like we had both to try
jthrasher1
06-19-2010 09:24 PM
bori bori
12-27-2009 01:25 PM
