i want to turbo my D15B7. i need help!
hi everyone! i'm new! hey does anyone know the requirements to turbo my D15B7 nonvtec SOHC from my civic DX. i need to know because i'm planning to go turbo by June.
Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1901612
here.....^</TD></TR></TABLE>
that does not really help...
but OP: if you search you will find it...
You'll probably want to use a different engine if you want much boost. Getting rods for the D15B7 is a pain... unless you find them used, like I did, only Crower makes them and they are over 700 dollars.
If you just want to run 5 PSI or so... try a Greddy kit. Be sure to adjust the arm down a bit since it's actually set around 7 PSI instead of the listed 5 PSI.
