Code 41: Primary oxygen sensor heater
Its a 98 HX with a 01 GSR Swap..
I just starting throwing this code my question is do i need a new o2 Sensor or is there something else to it?
Re: Code 41: Primary oxygen sensor heater (Civichx1998)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civichx1998 »</TD></TR><TR><TD CLASS="quote">Its a 98 HX with a 01 GSR Swap..
did you accidently take this out, and then start your car, if yeah then your fine you just need to remove cel light, i have no clue how process goes
---if this is not case id say yes you may need new o2 sensor ------
No i just got the swap in about 3 weeks ago i have a header i got from a friend of mine with the o2 sensor in it i just pluged it in never did anything..
I reset the ecu and it still comes on..
Re: (Civichx1998)
do you still have your old o2 sensor around. if so try put it in disconnect the battery to clear the codes and see if the code returns.
Re: (evilsolb16)
i never took it out.... I tried resetting it but it hasnt cleared... Im going to try my old o2 sensor out of my old motor and see if it will work... Just got to find some time to get it done... Anyone else have any input
924drb20
12-14-2010 10:36 AM
