96 spec itr bearing and brake pad questions
my wheel bearings are shot on my 96 spec lug swap.. looking to see what bearing is used.. i was told GSR is the same but doesnt seem like anyone is 100%
and same for the brake pads.. i was told gsr on them.. and im looking for a pad that is low on dust
any insight on this?
Re: 96 spec itr bearing and brake pad questions (Timmay)
You might want to put up more info. Which car? What did you swap out?
Same for pads...
I'm a bit confused on what you're asking really.
Same for pads...
Re: 96 spec itr bearing and brake pad questions (charjacq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by charjacq »</TD></TR><TR><TD CLASS="quote">You might want to put up more info. Which car? What did you swap out?
Same for pads...
I'm a bit confused on what you're asking really.</TD></TR></TABLE>
car shouldnt matter.. its 96 jdm itr lug swap so every part i have is from that
Same for pads...
Re: 96 spec itr bearing and brake pad questions (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">96 spec ITR is the same exact brakes as any 94-01 Integra (excl ITR), except that the hub is 4x114.3. Any wheel bearing and brake pad from a 94-01 Integra (excl ITR) will work.</TD></TR></TABLE>
thanks man you always seem to have good info
