dropping a b20b in a del sol and looking to see what I need
I am dropping a b20 in a del sol s. I was wondering besides the tranny, motor, mounts, axles, ecu, and harness. I am looking for what else I need.
I was told that I needed the rare shift linkage and a rear bracket. I was trying to make sure if that is all or is there anything else.
Any help will be good and thanks.
Re: dropping a b20b in a del sol and looking to see what I need (210racer)
bump
i might need this info in a couple of months
good luck with the swap
Re: (210racer)
you gonna need to convert your motor to OBD1...you gonna need an L bracket UNLESS your del sol is the DOHC Vtec model...alternator bracket....you gonna need 90-93 Integra axles, 94 up Integra axles, 94-97 Del Sol DOHC VTEC axles or 99-00 Civic Si axles...94-97 Del Sol DOHC VTEC linkage..the upper radiator hose for 94 Integra LS...the lower radiator hose for 94 Del Sol DOHC VTEC.OBD1 LS dizzy....94 Integra LS throttle cable...you pretty much converting your motor to OBD1 using OBD1 LS parts..you can keep the motor OBD2 but you gonna need a jumper harness which can rob some of your motors potential (according to hasport)
cody_sandlin
08-09-2013 05:19 AM
