need help wiring tach
blk= gnd, pretty simple, any ground. red= 12v, i used the poewr off my ignition switch(get a tester)whatever wire lights up when you switch the key. wht=lights dash lights, i used the one in the fuze box, blu= tach, I connected it to the one and only solid blue wire comin from the dizzy, or they say you can use the blue wire runnin in front of the fire wall before the shock tower(where your front shock is connected) theres a blue wire that leads to nothin. you can also try that.
HondaCivicSiR1
22
12-13-2004 10:38 AM
