Swappin b16a2 into a 99-00 ex...mount ?
are the mounts the same or would i need to replace the d16y8 mounts? im contemplating on doin a b16 swap.
* B A N N E D *
Re: Swappin b16a2 into a 99-00 ex...mount ? (B16b-EJ8)
Mounts off a 1999-2000 Civic Si along with the Rear Transmission Bracket. Add axles to the list and your about set
Re: (SIRIUS VTEC)
You guys are joking right? All the actual "mounts" are the same 96-00 period. He would need the rear T bracket from a 99-00 Si and thats it.
wiring harness should fit..i'm not so sure about the ek models but for eg's..it would just be plug and play if u have an ex or si..and just use a p2t ecu from a 99-00 civic si and u should be good.
Re: (EJ8CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8CIVIC »</TD></TR><TR><TD CLASS="quote">mounts of a 96-00 civic are the same?? i didnt think they were,
i beleive they are different bc of dseries to b series motors are different
Nope, they are the same. Just rear T bracket is all he will need.
Re: (SJersey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SJersey »</TD></TR><TR><TD CLASS="quote">
Nope, they are the same. Just rear T bracket is all he will need. </TD></TR></TABLE>
x2
x2
Re: (lilo_goki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilo_goki »</TD></TR><TR><TD CLASS="quote">wiring harness should fit..i'm not so sure about the ek models but for eg's..it would just be plug and play if u have an ex or si..and just use a p2t ecu from a 99-00 civic si and u should be good.</TD></TR></TABLE>
EK's dont have the same connection on the shock tower but you are right. If he used a P2T ECU it will work with his original harness. Harness is already an EX and would have vtec wired in already and he is set to go
All he will need is the P2T ECU, Rear bracket and axles. cant remember shift linkage but I believe he is ok. correct me if I am wrong... he may need the one piece
myEK=slow
13
07-13-2006 09:45 PM
lowcivex
02-18-2003 07:50 PM
