EX tranny on a HX??
EX tranny on a HX??
OK....so my tranny and stall converter from my 97 Civic HX just messed up. I just recently purchased a 97 Civic EX tranny and well I was wondering if it should work in my car? I have heard lots of rumors that supposably they are not the same, and well I know that but would it work in my car? Would the car run without a problem? I know that the HX tranny has some sensors and stuff like that and the EX dont. Would the car still work? Has anyone done this before? I would really appreciated if someone could help me out. THANKS!!!!
Stouts 'n' Scotch
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Is your HX an automatic?</TD></TR></TABLE>
He said he has a stall converter, so it must be.
HT White Ops
Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">He said he has a stall converter, so it must be.</TD></TR></TABLE>
He could be mistaken ... it's known to happen. I've had people think they have transmission coolers and torque converters on their manual Hondas.
That being said, I'm relatively sure you can't use the EX automatic transmission with the stock wiring harness and ecu, being as the HX auto is a CVT, and thus feeds information from different sensors into the ECU about what "gear" it's in.
Re: (Eran)
That being said, I'm relatively sure you can't use the EX automatic transmission with the stock wiring harness and ecu, being as the HX auto is a CVT, and thus feeds information from different sensors into the ECU about what "gear" it's in.</TD></TR></TABLE>
yeah its an auto.....so is the car going to work with the EX tranny without changing ECU's or anything like that? I just wanted to know what else I was going to have to change since I know my car has a CVT tranny....
HT White Ops
Re: (JesusGLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JesusGLS »</TD></TR><TR><TD CLASS="quote">yeah its an auto.....so is the car going to work with the EX tranny without changing ECU's or anything like that? I just wanted to know what else I was going to have to change since I know my car has a CVT tranny....</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">That being said, I'm relatively sure you can't use the EX automatic transmission with the stock wiring harness and ecu, being as the HX auto is a CVT, and thus feeds information from different sensors into the ECU about what "gear" it's in.</TD></TR></TABLE>
Re: (Eran)
Does any1 else know anything about this?..Do I really have to change the harness? I really appreciate your help Eran !!! but trying to see if any other members know anything about this...
Re: (USDMCIVICHATCH)
OK.....now where to you get all this info from...this is starting to su*k......jaja.. o well..is there anything else that its different?
Re: (JesusGLS)
OK....thanks for your help guys....I just went and checked it out myself and compared both of the trannys and they are way fuc*ing different....Wouldnt recommend for someone to mess up their auto HX tranny...jajaja...thanks anyways!!!
