Car wont star after swap!!!!HELP ASAP!!!!!!
We did a type r swap into a 93 civic cx, the typre came from a em1 obd2b, we got the obd harness and swapped everythin. When we go to start the car everything sounds good but the cars not pushin out fuel. Why is it not!? The car was runnin perfect before we did the swap. We had the stock fuel pump, then put a walbro 255lhp on it. still nohin.
fuel pump is overkill...by a lot
get rid of the obd2b ecu and jumper - run a chipped p28 or a stock p30
(You will have so many problems with that obd in that car)
Do you have spark? Fuel?
https://honda-tech.com/zerothread/1922346
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Start with pressure - what is it?
Are the injectors plugged in? Do they work at all?</TD></TR></TABLE>
x2
check out your main relay.
x2
Dr Pooface
09-28-2004 06:09 PM
