D16Y7 Coolant Hose Routing
D16Y7 Coolant Hose Routing & Turbo Vacuum Lines
Where does the hose from the pipe on the back of the block go?
In fact, where do all of them go just to be sure we have them all correct?
Got the one under the dizzy to the core switch, switch to firewall, firewall back to stat housing, the little one from the stat housing to the throttle body, upper & lower of course... I can't think of any others.
Also, when connecting the turbo vacuum lines - the outlet on the compressor-side goes to the side of the waste-gate, the top vents into the atmosphere, and the BOV goes to manifold vac, yes?
-RJ
Modified by 81CB900C at 3:41 PM 7/8/2007
Modified by 81CB900C at 3:42 PM 7/8/2007
-RJ
The hose from the nipple on hte water transfer tube goes to the IAC on the back of the intake.
And yes to the other question.
I guess you figured out where the bypass hose goes.
Re: D16Y7 Coolant Hose Routing & Turbo Vacuum Lines (EL Vap133)
... awesome.
We need to make sexi time and have lots of babies...
but seriously - it looks like it's saying the line goes from the tube to the intake nipple? because there's nothing there to hook up to. And that intake is a little different. I could take pics if it'd help?
Re: D16Y7 Coolant Hose Routing & Turbo Vacuum Lines (81CB900C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 81CB900C »</TD></TR><TR><TD CLASS="quote">liiiik 96 or 98? and yes.</TD></TR></TABLE>
Yes, sometimes they might change a few minor things or two.
2000vsm
08-25-2003 07:14 PM
