no start??
no start??
hey whats up guys ive been a lurker on here for a while. but now ive got a problem that i cant figure out and need better advice. i have a 92 hatch with a z6 swap. for some reason my car will not start up for about a half hour after you shut it off. when you try to start it when it dont want to all you can smell is gas. i have changed out the igniter,coil,fuel filter,plugs,head gasket,and i/m gasket. some one told me that i might have a leaky injector??? i am getting spark. i have a extra set of injectors but they are y8 injectors and i dont want to cut my clips on my harness if this is not my problem. when the car will finally start it runs like **** for about 10 seconds. any help is appreciated.
Almost does sound like leaking injectors, but check your timing. Do you have any cels? I would almost think maybe a bad ect (engine coolant temp) sensor but im not sure since you smell gas a lot.
there is no cels thanks for the help. i wish there was so i could narrow it down. i know the cel works because i had a bad speedo sensor and it threw a code for it but it is fixed
MattsGreenEG
04-23-2008 05:53 AM
