doing a vtec swap, some questions id like answered, please help
I got a sohc vtec free ( d16z6) from my uncle who is leaving for iraq, I have read and heard some peoples say I can use the stock wiring harness from the del sol its going in, even though the engine currently in the del sol is non vtec, is this true? if not where can I find a wiring harness for it? The vtec is in a totalled del sol SI and the wiring harness may be able to be saved but im not sure. all of your help will be greatly appreicated, thanks.
I've read before that all del sol s's wire pre-wired for vtec (not positive though), just as all 92 civics were pre-wired for vtec (dont argue about this one people, its a fact). If so then its just plug n' play, if not then do as mentioned above and wire it up that way. If you need a wiring harness for the head any z6 harnes will work out of any 92-95 z6 equipped civic.
Re: doing a vtec swap, some questions id like answered, please help (civicminded93)
ok thanks for your help so far. ok if i have to hook 3 wires up and one is ground, one has to be power, what is the third one for?
1 ground, 1 for the VTEC solenoid, and 1 for the VTEC pressure switch. http://www.ff-squad.com/tech/w...5.jpg
The VTEC solenoid wire is on a 1-wire plug & the VTEC pressure switch is on a 2-wire plug (one for the pressure switch and the other is the ground wire); so you can tell the difference.
Re: (CivicSpoon)
ive never done an engine swap, let alone a swap with a vtec, I am putting a sohc d16z6 in my del sol ( taking everything from the wrecked del sol si is goin on my del sol) so Im not sure how to do this. that link was showing for b series.
DelSolid21
09-29-2010 11:12 PM
97grnrs
12-18-2005 02:01 PM
GSR_deLsOL
05-04-2004 10:52 PM
