how much should i lower it
Re: how much should i lower it (my-black-si)
Its all on opinion, for me tucked is enough. In doing this though you get what you pay for. Do a search, they're threads like this and people post pics they're rides with whatever springs or setups they use.
Re: how much should i lower it (jb07_)
No finger gap, but does not necessarily have to be H-t means of "Slammed"
I prefer yellow Koni Sports and Ground Control Coilovers. You simply can't get wrong with their lifetime warranty
dump it.. if you live in calicommunist. ups sorry i mean california.. u'll love the way cops pull u over for dumping your car to low.. ... see you on court!!!
Re: how much should i lower it (itsmejto)
If it's your daily driver, and you don't wanna go over-bored, some good shocks with a "sport drop" will be enough. Not to low, not to high will do. Or, if you don't care about that, then I say slam it on it's nuts!
My coupe is my weekend car, so i might have to get her a jockstrap once the coils go on.
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my-black-si »</TD></TR><TR><TD CLASS="quote">whats up I have a 2000 si and I wanted to know how much i should lower it...</TD></TR></TABLE>
Ideally .75" to 1.75" with sport springs. You'll still be able to use OEM components - and still be within factory specs...
Beyond 1.75" you'll be have to start installing recalculated front a-arms, longer rear trailing arms, and all that rot!
You can go as much as 3" using coil-overs and struts but this will result in severe alignment problems, excessive tire wear, and won't be much fun to drive!
After that... you're on your own!
Here's a snappy of my DD:
1.75" front / 1.5" rear - zero gap with HX wheels - 4.5" ground clearance on front lip - perfectly driveable (if you watch yourself)...
wuggiewuggie
Suspension & Brakes
02-04-2007 12:42 AM
TougeCoupe
07-10-2004 07:05 AM
