9,000 rpm.. suggestions on head work??
I have a b16a in my ek.. i was just wondering on what head work i should do to it.. everything is stock but the ecu.. which makes the car go up to 9,500 rpm...and i don't want to blow my motor..any suggestions??? what kind of valve retainers?? Valve Springs?? you think new intake and exhaust valves??
Re: 9,000 rpm.. suggestions on head work?? (DB8_n_Ek)
valves, springs,retainers and cams....you should do high comp pistons and eagle rods so you dont spin a bearing....the choice or manufacturer is up to you
Re: 9,000 rpm.. suggestions on head work?? (.I.Need.Money.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .I.Need.Money. »</TD></TR><TR><TD CLASS="quote">How about... take out that shitty chip.</TD></TR></TABLE>
or just dont rev that high it would take a lot of work to make power at 9500 rpms on a b16 stock the powerband drops off at 78-7900
Re: 9,000 rpm.. suggestions on head work?? (EGhatchguy)
i ran a reprogrammed obd-0 mugen program on my 2nd gen b16 in my ef for 3 years with a full portflow spring and retainer setup and skunk 2 stg 1 cams and no headwork. redline was set at 10k and i never hit it but that motor ran awesome. i built the motor to rev with jun flywheel, single belt unorthodox pulley, skunk 2 intake and jdm 4-1 header. on the stock pr-3 ecu i got close to 400 miles to a tank of gas a few times. round town she was a lil ruff gettin n2 her powerband but man did that car sing from 5k and up. ed bergenholtz used unmolested heads on his crx back in the day just upgraded the valvetrain. the ruff casting helps the fuel and air mixture to atomize better for a cleaner more efficient burn.
Modified by biggdogg at 5:40 PM 6/17/2008
H-T White Ops
Here's why it's pointless to rev past the factory limit
The engine stops making power around 7800 RPM. Anything past that is pointless
1 Post
Re: (umair)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by umair »</TD></TR><TR><TD CLASS="quote">what if you have stock rods and you are revving to 9k? </TD></TR></TABLE>
with a chip bye bye motor... With a stock ecu you may have a goodtime for little while, but in due time same deal... bye bye motor..
My b16 has a built top end. It's got Ferria titanium oversized valves, springs, and retainers...ONCE, I reved it alittle over 10K when I got it...But now...I don't rev over 9k...My bottom end is stock. idk. Haven't had any problems...but I'm about to order new rods, and pistons ne how *shrugs*...i dont wanna wait till I spin a bearing...but seems to be ok for now...
2wheelhunter
08-15-2006 07:06 PM
Waachback
11
08-10-2004 02:41 AM
