water valve and a/c issue
hello i have a 98 civic hx, and i have seen many people commenting on the water shutooff valve for the heater when complaining about the a/c cooling performance. my car has 98k miles, and i drove my 12 minute drive from work today with the a/c off, just taking int he 80 degree outside air, and it felt slightly warmer, i think maybe than outside. but it may have been the trapped heat saturated int he dashboard. anyhoo, when i got home i checked the heater hoses, and all the way to the bulkhead [firewall] and the lines under the dash int he car were hot. does this mean that the water is flowing more than it should when the valve is shutoff? i guess i know its moving, but i want to know from someone who has a new or newer valve, is it supposed to fully stop all flow? or is a little seepage ok. i DO know that the cables for the heater flaps and the water valve are adjusted correctly, and that the valve is moving when the cable is moved. for what its worth the heat works great. thank you for your help. i just want to know if this vave is affecting my a/c at all. the a/c i put in as a NEW honda option from a dealer and the system has only been in for 1.5 years.
Sometimes it's nothing to do with the water valve ? most cars just redirect the air instead of using a valve. Sometimes it's just the heat from the engine blowing over the hood into the intake vents that can create a temperature rise over ambient temps.
Modified by itsmejto at 8:18 PM 6/18/2008
