Sunburn windshield
Sunburn windshield
Is there anyway I can get rid of that sunburn effect on my windshield? I've cleaned the inside and outside of the window thoroughly with different described methods and nothing. I'm not sure if there's much I can do, but if anyone has any ideas I'd appreciate it.
ttt. would like to have more input. It's tough to see in the rain with it the way it is, and I can't afford to buy a completely new window.
H-T White Ops
FV-QR
I'd really recommend against aircraft stripper or anything else that strong.
Front windshields on modern cars often have a plastic coating on the outside. So even cleaning with somethign like wheel acid can burn the plastic coating, turning it a white color.
I've never heard of a "sunburnt" windshield though. I'm thinking it could have been damaged how I just described.
Re: FV-QR (NOFX)
Well, I'm not sure if "sunburnt" is the right wording, but that's the only way I could explain it. When I notice it is when it's raining, and with the glare from other headlights, as well as the windshield wipers moving, the windshield looks colorful almost. It looks like the drops of rain that don't dry fully, and leave some residue behind, but it's just colorful.
But I'd think steel wool would scratch the window surface.
H-T White Ops
Re: FV-QR (iheartrice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartrice »</TD></TR><TR><TD CLASS="quote">Well, I'm not sure if "sunburnt" is the right wording, but that's the only way I could explain it. When I notice it is when it's raining, and with the glare from other headlights, as well as the windshield wipers moving, the windshield looks colorful almost. It looks like the drops of rain that don't dry fully, and leave some residue behind, but it's just colorful.
But I'd think steel wool would scratch the window surface.</TD></TR></TABLE>
"Colorful" makes it sound like there could be some sort of residue, like oil, on the glass.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartrice »</TD></TR><TR><TD CLASS="quote">But I'd think steel wool would scratch the window surface.</TD></TR></TABLE>it doesnt just try it
Yeah, it almost seems as if there is an oil on it somehow. I used normal windex, and nothing. I also bought some RainX streak free glass cleaner, and there wasn't a difference.
I also have, 1 month old, RainX latitude windshield wipers.
What would work on cleaning oil off of a windshield? I only had the car for a few months, so it's possible that somehow the previous owner spilled some kind of liquid on it.
H-T White Ops
Re: (iheartrice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartrice »</TD></TR><TR><TD CLASS="quote">Yeah, it almost seems as if there is an oil on it somehow. I used normal windex, and nothing. I also bought some RainX streak free glass cleaner, and there wasn't a difference.
What would work on cleaning oil off of a windshield? I only had the car for a few months, so it's possible that somehow the previous owner spilled some kind of liquid on it.</TD></TR></TABLE>
Eran used to have an oil leak on his Y7. It was from the head and was successful in misting a light spray over the glass. This caused his passenger side of his windshield in particular to get very oily and "colorful".
I don't think we ever managed to remove the oil, not that I ever tried. I'm not sure if he ever tried, but it was always there even after a fresh wash and window cleaning.
It ruins cloths that you use on the oily place too btw. So I wouldn't recommend using the cloth elsewhere after you wash or dry that area. It will just drag the oil elsewhere.
I almost promise you have a small oil leak. Like a breather or something.
H-T White Ops
Re: Sunburn windshield (Frost7177)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frost7177 »</TD></TR><TR><TD CLASS="quote">brake clean it had the same problem with oil all gone.</TD></TR></TABLE>
This could also damage the windshield.
Be careful what you use on it. It might not damage it, but I'm not sure if you'd think it's worth the risk.
Haha, yeah. I want to better the problem, not cause a worse problem.
Could it be the cheap windshield washer fluid that came with the car? Or is it all the same ****, whether it be RainX or not?
I understand your frustration with the sunburn effect on your windshield. While it can be challenging to completely eliminate sunburn effects on glass, there are a few methods you can try:
1. Vinegar solution: Mix equal parts white vinegar and water in a spray bottle. Spray the solution onto the windshield and let it sit for a few minutes. Then, use a microfiber cloth or sponge to scrub the glass gently. Rinse with water and dry with a clean cloth.
2. Ammonia-based cleaner: Dilute an ammonia-based glass cleaner according to the instructions on the product. Apply it to the sunburned areas of the windshield and let it sit for a few minutes. Wipe the glass using a clean cloth or paper towel. Be sure to ventilate the area properly when using ammonia-based cleaners.
3. Rubbing alcohol: Moisten a clean cloth with rubbing alcohol and gently rub the sunburned areas of the windshield. This method can help remove some of the residue left by the sunburn effect. Rinse the glass with water and dry it thoroughly.
4. Glass polish or cerium oxide: If the sunburn effect persists, you can try using glass polish or cerium oxide, which is specifically designed to remove stubborn stains and scratches from glass. Follow the instructions provided with the product carefully and apply it to the affected areas of the windshield.
It's important to note that the effectiveness of these methods may vary depending on the severity and duration of the sunburn effect on your windshield. If none of these techniques yield satisfactory results, you might consider seeking professional help from an automotive glass specialist who can provide additional advice or services to restore the clarity of your windshield.
Remember to always exercise caution and follow the product instructions to ensure your safety and avoid damaging the windshield. Good luck, and I hope you find a solution that works for you!
JDMJUNKIEMONKIE
15
11-06-2009 06:16 PM
