Emission/Idle/MPG Problems
Re: Emission/Idle/MPG Problems (JDMReverend)
Have you checked the IACV? Mine was idleing at 2-3k and I replaced that and it sits about about 1200 now... I picked up one at the junkyard for $6
Re: Emission/Idle/MPG Problems (honda_joe)
Can't post CEL's cause it won't tell me what codes it's throwing. I'm thinking possible bad ecu. Start the car up, cel is lit, and if you jump the plug to get it to throw codes, it stays solid. Tried disconnecting the negative and removing the ecu and the backup fuses and it won't reset, or the light comes back on immediately and still idles high.
The CEL will stay solid if there are no codes stored when you are jumping the service connector.
Are you sure you are jumping the harness properly? A lot of people try to use paperclips--- a lot of paperclips have a coating on them and they won't conduct.
