H22a plastic shifter?
is anyone in here running an H22 swap with a plastic shifter base?
do they sit higher?
are there any drawbacks, or advantages?
do they sit higher?
Re: H22a plastic shifter? (nix94delsol)
WELL I CURRENTLY DID A H22A4 SWAP INTO A 95 EG... THE PLASTIC SHIFTER BRACKET DOES SIT TOO HIGH .. IN THIS CASE ALL THE EXTRA PLASTIC IS CUT/SHAVED OFF UNTILL IT CAN SIT MORE FLUSH WITH THE BODY.. U CAN FIND MORE INFO AROUND JUST KEEP LOOKING...
Re: H22a plastic shifter? (Bangher4$)
thanks for the input guys
has anyone had experience with both?
prefrences?
maybe i should try the Lude forum too....
prefrences?
In my experiance, the platic shift box would streatch cables, i also have a short shifter piece on it. Switched to the metal kind from an accord, shifts the same with different throw. Easier to install too, just tak-welded it down. <----lazy
stehigs321
12
10-03-2007 09:39 AM
