My D16Y8 keeps on stalling coming to stop or pressing on the clutch pedal.
Old 09-25-2008, 05:43 AM
chickenwing's Avatar
Default My D16Y8 keeps on stalling coming to stop or pressing on the clutch pedal.
I have checked and rechecked my timing, idle and cleaned the IACV and throttle on the D16Y8.
I do not have any CEL lights at all and it starts and idles fine now.
The problem I have is that after driving it when you come to a stop and press in the clutch the idle dips very low and most of the time it stalls. With the A/C on it will stall less.
The modifications I have on my D16Y8 setup with stock P2P ECU.
Added wiring for Vtec solenoid, Vtec pressure switch, knock sensor, and 3 wire to 2 wire IACV modification.
competition cams,
short ram air
aluminum flywheel and 6 puck.
4-2-1, 2.5 inch header, test pipe, exhaust
spark plug fouler trick for the second O2.
new fuel filter, new cap, new rotor, new sparkplugs,
Modified by chickenwing at 6:57 AM 9/25/2008
Old 09-25-2008, 06:18 AM
Bakeoff's Avatar
What cam are you running?
Old 09-25-2008, 06:36 AM
Default Re: (Bakeoff)
it is a 260 VTEC 1.6L cam
competition cam #105300
Old 09-27-2008, 04:07 PM
Default Re: (chickenwing)
checked the tps as suggested by a member and i get 0.47V closed throttle and 4.5V at WOT.
this is one real big problem stalling everytime I press on the clutch coming to a stop.
hondaciviceg4dr
01-31-2015 06:00 PM
whokid_911
02-13-2011 08:13 AM
brusk13
04-10-2006 04:46 PM
Devilry
11-19-2005 09:39 AM
turbopanda
03-20-2005 08:02 PM
Quick Reply: My D16Y8 keeps on stalling coming to stop or pressing on the clutch pedal.
