Broken Lug Nut Studs
Alright so I have two broken lug nut studs. I bought all the parts to fix it, but the problem is that I can't get the hub off to get the old studs out. I've tried just about everything. Anyone have any ideas?
Re: Broken Lug Nut Studs (d16skivic)
you need a hub puller, and your going to need a press. and your going to need new wheel bearing(as they always say you should just in case).
or you could ghetto it and just use a wheel grinder to grind of the rest of the stud. punch stud out. with the new stud grind part of the bottom so that you can slide the wheel stud around the hub, and use a lug nut to pull the stud through.
Toy Civic
06-06-2008 01:06 PM
