EG w/H22 won't rev! :(
I am running a 37820-p13-n00 computer in an H22 swap into an EG.
A code that came up was for EGR (code 12), which I fixed - I took an EGR control valve off of a '94 Prelude and wired it up everything including the vacuum lines.
I drove the car for 10 miles and there was no check engine. Then, I drove the car again for another 10 miles and the car won't rev past 6500 (still no check engine). I swapped the computer with another (37820-p13-n01). The car still won't rev over 6500.
I don't want to use a GSR computer or a P28 because I am trying to ref the car.
If anyone knows what the problem is or what I should try from here, please let me know. I would really appreciate the help.
Re: EG w/H22 won't rev! :(
if you are running a resistor box check that.i had the same problem and i elimnated it and it fixed the problem.hope this helps.
harv
harv
byrne_06
09-16-2009 09:16 PM
