97 hx coupe, taillights will not come on
Having an issue with my lights. The tail lights do not come on when i turn my hadlights on. Also, my running lights will no come on, or the side blinkers we installed will not come on. I bought a new headlights switch assemly from honda, but that did not fix the problem. All the fuses seem to be in good shape. Has anyone else had similiar problems?? This jus started messing up.
Mike
Mike
H-T White Ops
Re: 97 hx coupe, taillights will not come on
Have you tried a different fuse anyway?
Are you sure they're getting correct power to the light sockets?
Not really sure where to start, but the bump might help you.
Tried other fuses, they didnt work. It used to work, but then one day they just stopped working. Not sure whats wrong or where to start..
Mike
Mike
If all the lights are having issues working I'd say you have a bad multi-function switch, but apparently you already replace that with a new one. Are you sure the fuses are good? Sure you didn't short out a wire somewhere? Sure the relays are all functioning properly?
Can someone give me an idea of which fuses to check? Anyone got a diagram or something and can circle the fuses to check.
Mike
Mike
Search for an online factory service manual or stop being cheap and buy the Hayne's manual from your local parts store. They have all the wiring diagrams in it.
I just noticed that my reverse lights are on all the time too. Any known connection between the 2 problems?
Mike
Mike
ern1523
08-26-2011 02:45 PM
vi3tzkidd
09-27-2009 12:21 PM
skylinexr
05-08-2007 02:30 PM
