Transmission Jerking
Old 01-01-2009, 03:41 PM
burntkookie's Avatar
Default Transmission Jerking
First of all my 1994 honda civic ex automatic tranny has a jerking motion when im close to completely stopping..The only way to not to make it jerk is to make a hard stop. What should I do?Replace the tranny, if so what tranny should i get, i still want to have an automatic tranny.
Old 01-01-2009, 03:45 PM
Resident Gearhead
BryanM.'s Avatar
Default Re: Transmission Jerking
How did you come to the conclusion that the transmission is to blame?
Old 01-01-2009, 03:53 PM
first i thought i was my tranny fluid so i changed that, changing the fluid helped also i noticed that there are metal pieces.. Also i changed my front brakes and that didnt help at all..
Old 01-01-2009, 04:02 PM
namewasdallas's Avatar
could be a broken engine mount causing it to jerk, take a look at all the mounts
Old 01-01-2009, 04:07 PM
Where are the engine mounts located at?
Old 01-01-2009, 04:26 PM
Forgot to tell you guys i went to a tranny shop and they said it wouldnt be the engine mount..What kind of tranny would fit in my civic?
Old 01-01-2009, 05:07 PM
318 Curves, 11 miles
Vindicator9000's Avatar
Any automatic from any 92-00 civic should fit with minimal modification. Or you can swap to manual, which I've heard is not that hard either.
I've had a torque converter cause those symptoms on a 92 pontiac once. Which is somewhat transmission related.
Old 01-01-2009, 07:09 PM
Seagull Management
94EG8's Avatar
You cannot use a '96 - '00 tranny, there are some major wiring differences. You can use either an M24A found in any automatic '92 - '94 civic or the A24A found in any automatic '95 civic. From the little experience i've had with both the M24A seems to be better. You can as others have stated rather easily swap in a manual.
krisfnbs
11-15-2008 04:40 AM
johnca
05-22-2006 09:24 AM
TurboEM1
23
04-28-2006 04:09 AM
GDM93Si
12-31-2004 09:05 AM
DSC
06-30-2002 01:15 AM
Quick Reply: Transmission Jerking
