CAT removal HELP!
CAT removal HELP!
My CAT is clogged. It is disconnected at the header. Now Im just trying to get the bolts off the other side of the CAT. They are rusted on good. So I got a grinder and cut the heads of the bolts off. Didnt touch the nuts because I didnt want to damage the exhaust piping Im still gonna use. The heads of the bolts are cut off. I cut into the CAT good you can see the outline of the bolt in the metal. I put PB Blaster and hit the end of the CAT with a big hammer and wont come off. Even tried a chisle wedge in the 3 corners no luck. Any ideas?? Maybe get it red hot with a torch??
-Thanks
-Thanks
Re: CAT removal HELP!
-Thanks
-Thanks
i had same problem. i unhooked my hangers on my exhaust and wiggled my exhaust around untill the cat was out the side of my car and went at it with a hack saw since i didnt have a grinder... you can try it that way if you want.
