Will a bad igniter throw a code?
Im trying to figure out why my car has no spark. If the igniter is out will it throw a code? There are no codes? the Ignition coil has .9 resisitance??
Re: Will a bad igniter throw a code?
A bad igniter may throw code 15 for 5th generation (OBDI) Civics. I don't think the same would be true for a 6th generation Civic, unless it registers as random misfiring.
Do you have battery voltage at the distributor connector?
its a 93 civic ex i took the distributor out. yes there is battery voltage
Assuming all the wire connections are fine, the igniter unit is probably bad. There's no direct test described in the manual for a bad igniter, but your local auto parts store may be able to test it for you. Bring the coil in for testing as well, just to confirm your resistance measurements.
Ignition Control module commonly goes out car won't start. Or it will stumble in the upper OR lower rpms. You can have it tested at O'reilly's what exactly is your problem?
the car died and wont start, the local auo parts stores dont have testing equipment. Was trying to figure out if it was the ignitor or icm. Maybe i should just buy a whole new distributor from distributor king.
Buy the igniter and return it if it doesn't restore spark.
Distributor King's dizzys get good and bad reviews. If you can afford to buy a new OEM ignitor and/or coil, do. They will last longer.
On the other hand, for a car this old, a whole new distributor may be a good idea. The dizzy housing, for one, has three engine control sensors in it that I think degrade over time. I advise at least a new housing (which is not a whole distributor) every 150k miles/10 years.
The Hooligan
12
07-20-2010 08:51 AM
Charles B.
03-16-2004 09:37 AM
Sobe_Death
03-11-2004 10:09 AM
