How to lengthen Transmission Gear ratios?
I am thinking about boosting a 00 civic si. But im told that it would be a real neck snapper since the gears are so short. Is there anyway to lengthen these gears?
Re: How to lengthen Transmission Gear ratios?
I'm no transmission tech, but I'd say to research a different transmission, or do some real homework and find out if you can swap in a taller final drive/different gear set.
Yea i really dont wanna swap the tranny because i lik the si's ill look into the gear set though. I just heard around that you can lengthen the gears but they didnt know how
It's not just as easy as "lengthening" the gears, theres some serious work involved regardless of what route you decide to take.
On a realistic note,just swap out the transmission for either a gsr or ls
like another has said your cheapest most beneficial route is to purchase a GSR trans. It would be cheaper than increasing the final drive in your b16 tranny and better for boost
If it is for the track... a larger wheel size will increase your overall final drive. If not get ready to spend some money on intenrals
Back on topic guys...don't go get your thread locked. You need answers not arguments... lets work on it.
But seriously. Leave your Si tranny in there. I have lots of friend's boosting on Si tranny's on all different levels of setups.
Yeah and one thing to point out is if you go get a GSR tranny... they are a little longer after 1st gear. The SI tranny is worth plenty and could prob be swapped with someone looking for something shorter. I myself chose an SI tranny over my GSR. But then again I am NA
But like we were saying, lots of people use a SI tranny. Those boosting look for smaller more reactive turbos. Something to think about
Not at all. The tranny's pretty much eliminate turbo lag. There cars spool so fast. What kit are you going with or what size turbo?
MurkyRiversEK
Transmission & Drivetrain
19
08-14-2012 12:45 PM
