my car is just rurning but not starting?
1 Post
b20v.
blox FPR
the car does this at random times...mainly it does it after i've driven it and have shut it off.it just turns and turns but wont start, it will after letting cool, or if i push start it i've replace the coil, the rotor and the wires and the spark plugs and the battery, but not the cap. I've also replaced the main relay for the fuel pump.
what is it.
blox FPR
what is it.
Re: my car is just rurning but not starting?
my hatch did the did the exact same thing last summer. i thought it was the injectors. so i took them out to change and they were all covered in carbon. took some scotch brite to them and put them back in started every time after
1 Post
batt is new.
and damn. i was going for the injectors once but lost track of them. i taking care of those first thing in the morning. hope this is it guys. wish me luck. i'll let you guys know thanks and keep them suggestions coming please.
1 Post
MAN! i cleaned the injectors. and i think that it might have been the problem. bit they only build up on the outter lip. and a little bit of dedrie in the filter insert. how does this effect the filters?
ya thats where mine had it to. i just cleaned them up real good and had no problems. let me know if it works out
bad connection to the starter/battery? i had a friend car that did that and i replaced the terminal ends and it turns on.
1 Post
it's not missfiring, and i do think that my dizzy is giving spark for every cyilinder, cause when i turn it on it runs strong. how can i check tho?
well if it runs strong once it gets started then its sparking in every cylinder. But you might need a new dizzy. This happened to my friend with his GSR. Finally it stopped starting all together. He found that the dizzy had cracked and had oil in it, so it had to be spinning faster to create a spark (not sure why).
1 Post
sorry to make this come to the front page. but I'll post how i fixed it for future issues anyone might have like mine.
the issue was the fuel pump.
i changed it out and the car was always starting.
thanks HT.
thanks HT.
1baddcivicsi
26
10-13-2006 04:17 PM
