SIR fog lights? wiring
has anyone ever wired a set up with the OEM switch and harness
I have everything but the wires between the harness with the switch and relay and the fog lights
Re: SIR fog lights? wiring
So, you are missing the wire running from the switch harness to the fog harness? You can run a single 18G wire through the firewall to connect the two harnesses. This is what I did in my 92 hatch, since there wasn't one from the factory. I crimped on female-side spade connectors on the ends which plugged into the harness connectors.
I know where to plug everything in to the harness at but then what? i mean what do i have to splice after that and what one
Matty.
14
01-02-2006 03:49 PM
hYbRiD EeEkAy
02-02-2004 04:29 AM
