Short shifter in a hatch wth engine swap.
so i have an eg hatch and im lookin at swapping in a b16 (hydraulic tranny) from a 92-95 SiR, and i was told to use a linkage from a 94-01 teg. I figured id just do a short shifter while im doin everything else.
What short shifter do i need? I wasnt sure if id need one to match the car, the motor, or the linkage.
Re: Short shifter in a hatch wth engine swap.
you can use the d-series single bend short shifter or you can use the b-series dual bend short shifter. same thing but the dual bend sits back further.
any preference? ive never played around much with short shifters.
I know ebay parts are usually junk, but some things are ok to buy off there. Would a short shifter be something you could buy off ebay?
I would recommend not getting an egay one . Ive had a personal experience with one a few years back In my ef. I was driving spirited maybe a little harder than normal and when I went to shift into second the whole threaded area snapped off with the shift ****.So i drove for a week with a little tooth pick sized **** since there was no ****
Cool Cool Island Breezes. BOY-EE
If you're using an integra linkage, you need an integra shifter. The linkage for integras is wider right where the shifter meets it.
F it. Buy an EBAY one. They're cheap. It's just a stupid shifter. I got a SKUNK2 one for free. I really like it...but I don't think I'd be willing to pay full price. My EM1's just my DD.
Dual or single bend is a preference thing. I like the dual bend because of how it sits.
okay well im not so sure the dude who said about linkage knew his stuff...
a 94-01 integra linkage WILL in fact work with the 92-95 B16a motor (hydro tranny) in the 92-95 civic dx hatchback? and then just go with a 94-01 short shifter? do i need to throw down 150 bucks on a new linkage or is it reasonable to buy a used one?
thisll be my first swap, im just trying to get all this info straight.
B Serious:
I was always under the impression that the shift linkage just needed to be from the motor that is being swapped. Is this incorrect? Also on that note, aren't B series interchangeable?
yeah anyways. bc the motor is on hmotorsonline.com, and they send you the stock linkage for the 92-95 SiR. I dont want to spend 150 bucks on an avid racing 94-01 linkage when i can use the one they send me for free, if i can in fact use said linkage.
yes ther are interchangable.you can use anylinkage as longs its for a b series tranny.you can either get a integra short shifter or a 99-00 si shifter.i have a "jdm" ebay one myself.you can also use civic shifter with your teg shift linkage but youll need to use washers to fill in the space.
318 Curves, 11 miles
Yes, any B or D shifter should work on a civic linkage. I'm using the same B&M dual bend on my B swap as I used on my D motor. The B&M shifter is a nice alternative to an ebay shifter... they're quality, and only about $50. I got mine from modacar.
Unless I'm mistaken, any B linkage should bolt to any B transmission... but it may not fit your car. If you have an EG hatch, your best bet would be to use a B series linkage from an EG - either SiR or Del Sol. I'm not 100% certain, but maybe someone can clarify.
itll be the linkage from a 92-95 SiR but i guess they didnt sell them cars in america. and itll go into a usdm 92-95 eg. I was assuming it would fit... going from a 92-95 to a 92-95, idk why i gotta jump all the way to an integra linkage...
The EM1 shifter is the same as any D series shifter. It's got the smaller portion below the ball.
The integra shifters are different. The integra linkage requires an integra shifter or a big washer on a civic shifter.
You CAN use a civic shifter on an integra linkage (with a washer).
You CAN NOT use an integra shifter on a civic linkage.
I have an EM1. I used to have a GSR. The shifters are different. I guarantee you this.
I think the linkage I got with my OBD1 Si-r swap came with an integra linkage from H motors. It was still in Honda bags.
For example:
You have a 95 civic with any B series manual swap. You can use an EM1 linkage, a GSR linkage, or a JDM SI-R linkage. Obviously, the CTR or ITR linkage will work as well.
You have a 95 DEL SOL VTEC and you swap in another type of B series. You reuse the Del sol B16A linkage. You can't use the EM1, GSR, ITR, CTR linkage.
The only difference between integra linkages and civic linkages is that the slot where the shifter sits is wider on integras. So with an integra shift linkage, you must use an integra shifter or a civic shifter with a big washer on one side.
The integra shifter is also a-symmetrical. Which means, obviously that the fork part of the linkage is also a-symmetrical. Not important. Not a big deal.
The del sol linkage is longer. You use a civic shifter on all models of the del sol.
ok so all this is confusing me like hell right now. so heres a question, looking for a yes or no answer to sum it all up:
92-95 hatchback civic.
92-95 SiR B16a motor with hydro tranny.
92-95 SiR B16a linkage.
92-95 civic dual bend short throw shifter.
all this will hook up, no issues?
I DO know what I am talking about. The linkage will have to be a 94-01 integra linkage for the b-series into eg chassis. As far as your question about the shifter though (short shifter) you can use a eg or dc shifter. It is a personal preferance. I have the stock eg shifter in my car because I am tall and have long arms. If I were shorter, I would use the dc dual-bend because it sits back further.
with so many ppl doing b series swaps, i find it odd that im hearing multiple answers to forming the solution.
Dude im not questioning your statement. i was originally told about the 94-01 linkage on another post. Then i was thinking, and if the b16 came from a 92-95 civic, wouldnt i just beable to use that linkage to put it back into a 92-95 civic? If its the same chassais, only dif is that it came from an asian car and is going into a car sold in the us, i figured it would make sense not to spend the money on a dc linkage. your post agreed with his statement, which made the situation rather confusing.
2k1_ITR_0736
31
07-20-2002 08:41 AM
