Brake light problem
Brake light problem
I'm having a problem with my brake light when the lights are off and you press the brake it works fine but when you turn the lights on and press the brakes it doesn't light up at all does anybody have any ideas?
Re: Brake light problem
Odd electrical problems like this are typically caused by bad ground wire connections. Start by checking and cleaning the ground wire connections in the rear.
Iv'e checked all fuses and there dine and yeah my horn works. I'll have to check the grounds. There is some corrosion on the socket from moisture in my tailight.
I changed the bulb already so i'm thinking its a grounding problem i was just confused cause it lights up with the lights off but not when there on
I ran into the same problem. I ended up having to buy a new bulb socket from a junked car. It seems that the corrosion inside the socket caused the bulb to work intermittently. So, check the socket and see how bad the corrosion is inside it. A new bulb may help because the bulb itself isn't corroded but it is the socket that really needs the help.
