Aftermarket EG suspension fit an EK?
Does anyone know if aftermarket EG suspension will bolt up to an EK Hatch?
Im specifically looking at K-Sport Kontrol Pro, on the website they have different part numbers but the same spring rates
Re: Aftermarket EG suspension fit an EK?
i'd do some research if i were you. when shopping for suspension for my del sol, i saw that 92-00 were all the same for front and rear struts
EK LCA's are longer than EG LCA's you can use EG suspension on an EK all you need are 2 thick washers for each lca...Skunk2 sends washers in there kits for use on EK's.
Another question... When removing the rear damper fork bolt on the EKs do these break easy? Do we reuse the stock bolt with the K-Sport coilovers or does it come with a new one?
Demon_Dub
09-25-2005 01:18 PM
